Ayesully810 Posted June 27, 2018 Report Posted June 27, 2018 I cannot get my rear brake to lock up at all. it works but if I had to slam on the brakes it wont lock up. I have a plus 4 line on a stock arm, does that effect anything? Ive bled the line and got as much air out as possible. Brand new oem caliper and pads. Quote
JUSTWANNARACE Posted June 27, 2018 Report Posted June 27, 2018 You still have an air pocket somewhere, or your master needs rebuilt. If its holding pressure and not leaking out the master then that is probably fine. Also check the adjuster at the pedal. If you lengthen the rod it will engage more Quote
Ayesully810 Posted June 27, 2018 Author Report Posted June 27, 2018 7 minutes ago, JUSTWANNARACE said: You still have an air pocket somewhere, or your master needs rebuilt. If its holding pressure and not leaking out the master then that is probably fine. Also check the adjuster at the pedal. If you lengthen the rod it will engage more lengthen the rod by unscrewing it right? take all the slack out of it basically? Quote
JUSTWANNARACE Posted June 27, 2018 Report Posted June 27, 2018 (edited) Loosen the jam nut at the clevace and unscrew the clevace Edited June 27, 2018 by JUSTWANNARACE Quote
Ayesully810 Posted June 27, 2018 Author Report Posted June 27, 2018 (edited) 4 minutes ago, JUSTWANNARACE said: Loosen the jam nut at the clevace and unscrew the clevace okay yeah i did thata little bit but i could probably do it more, i didnt know how far was too far. Edited June 27, 2018 by Ayesully810 Quote
