dezracr Posted June 9, 2018 Report Posted June 9, 2018 I have a 98 banshee I have FMF gnarly pipes and power core 2 silencers, v-force reeds, stock air box with a pro design billet adapter and foam air filter, she ran great until I changed the clutch cable ant throttle cable now after running 6th gear wide open I let off and get back on it the right cylinder shuts off it wont fire, it has the stock parking brake but all the switches have been removed and tors is gone, the wires for the parking brake switch is pulled out of the loom, my carbs are set at 27.5 pilot, 280 main, 2 1/4 turns on air screw carbs are synched Im out of ideas, I work at a Yamaha dealership so Im ordering new needle valves, all new carb hoses and the carb connect hose. and gas cap I replaced the petcock o-ring and packing when I pulled off the fuel line it sprayed gas like it was under pressure on the right side carb. Quote
