sleeper06 Posted June 1, 2018 Report Posted June 1, 2018 That’s 1211 that someone used to seal the intake boot to the billet manifold, they just were not neat about it. As for you, time to make a pressure tester . Either your rad cap is letting coolant push out, or your burning it. Some simple tests will tell you a lot about the condition of your engine n seal Quote
ginger Posted June 1, 2018 Report Posted June 1, 2018 13 hours ago, Ayesully810 said: if you did have a leak into the combustion chamber idk how the coolant would make its way into the reeds and then to the boot but what do i know. both sides like that? assuming he isnt running a recovery bottle it will be low when cool. when up to temp its going to push coolant out. without the bottle to recover the fluid, when it cools down it will suck air in. Quote
