pawanuppal Posted July 17, 2017 Report Posted July 17, 2017 Hey guys I just got a banshee and brought it down from about 1200 ft elevation to around 300 ft elevation. It does bog when trying to take off unless i take off like im about to race. The temperature is about 20 degrees Celsius (68 degrees Fahrenheit) where i am located. It has a toomy 2 in 1 filter but everything else is bone stock. I had it out in the sand today and it spewed coolant and emptied the reserve bottle. I think this is becuase of a lean condition which is causing it to run hot. Can anybody please help me as to which jets i should order and put in? Elevation 300ft Temp ~70 Fahrenheit Mods toomy 2 in 1 air filter Stock carbs but i am not sure what jets it has as of right now. Thanks! Quote
JUSTWANNARACE Posted July 19, 2017 Report Posted July 19, 2017 Stock pipes? If it's bogging off bottom you probly need to go up on the pilot jet Quote
