New to this sight but need help.  Was wondering if anyone has a way other than swapping parts to check for intermitten or weak spark?   Have 135 psi compression and everything else obvious checks out but won't start without starting fluid and left side exhaust is cold
  • 2 weeks later...
Get inline spark testers. Ohm out caps, coil, stator , check pickup gap, sync carbs with vacuum gauge . It could very well need more fuel or idle circuits could be clogged, they are a needle sized hole
