Hi! I'm electrical systems retarded.
I have a high output stator that's been rewound and DC converted by an HQ member.
I am wondering, if I were in a pinch and needed a stator, can I use this rewound high-ouput stator on a bike that doesn't have an upgraded reg/rectifier nor headlights?
If so, do I connect it like normal, both bullet connectors and the large square white plug?
Thank you for the fast responses guys!
And if the Albino you are referring to is Gary, then yes sir!
So, connect the bullet connectors and the square white plug, but keep the headlights unplugged from the harness and I should be good to go?
I didn't even connect the bullet connectors. Just the wires for the CDI and coils. I would suggest for 100% to ask gary as he would know best.
Good point!
Although I can never remember his screen name.
Do you know it, can you PM me his screen name?
sheerider1026 but send him a message on fb, he will get it faster
Ahh, that's right!
Thank you!
Reason I'm asking this question is that I'm going to fire the Powerline dune port 350 today and I'm just trying to cover my ass with a spare stator in case the roached out stator that's in the motor that Don at Powerline built for me gives me any trouble.
I hit up Cory from Kompulsive Koncepts and he said I can run the rewound stator and that since I'm not using lights to just plug the main plug into the harness and leave the two bullet connectors unplugged.
My old stator was a high out put and  I still ran it no problems without all the lighting hooked up.
