Avilla87 Posted May 16, 2017 Report Posted May 16, 2017 I'm thinking about selling my banshees. The fist 1 is a 1989 jarm that I build from the ground up about 2 years ago. It has a 7 mill cub that makes 102hp on pump gas. The second is a 4 mill cub that is brand new I have only been able to run it through a couple heat cycles. Below are the specs 1989 7mill Motor: 7mill cub cylinders ported by D&M racing 7mm crankwor billet crank Hinson clutch basket. Mattoon lockup Chariot billet 1 piece intakes Vforce 4 reeds Keihen 39mm carve with chariot billet bowls Shearer bigbore inframes Converted to dc power for hid Chassis: Lightened 1989 frame with chromoly subframe +2 -1 metal tech j-arms 13.5 Marvin Shaw hill shooter from shocks +10 metal tech swingarm Works ultra cross rear shock Jj&a hillshooter axle Drag cut Douglas wheels front and back 22x11x8 10 paddle extremes Lone star antivibe steering stem Painted full of plastics The second bike is a 1993 4 mill cub Motor: 4mill cub cylinder 4mill hotrod crank Chariot clutch basket Direct drive lockup 35mm keihin pwk Chariot 1 piece intakes Vforce 4 reeds Sheare inframe small bores Converted to dc power for hids Chassis: 1993 chassis lightened with chromoly subframe Lone star +2 +1 a-arms Works double rates in front +8 metal tech swingarm Works black widow rear shock I'm asking 7500 for the 7mill and 5500 for the 4mill. Pm me with any questions. Sent from my iPhone using Tapatalk Quote
Avilla87 Posted May 16, 2017 Author Report Posted May 16, 2017 Thank you. For anyone interested the bikes are in Arizona. Sent from my iPhone using Tapatalk Quote
rjdgriff Posted May 16, 2017 Report Posted May 16, 2017 Good looking bikes for sure glws Giving away "TSS" for FREE!!! Quote
Avilla87 Posted May 29, 2017 Author Report Posted May 29, 2017 Bump. I am open to reasonable offers and will consider parting them out but I would like to sell the motors first. Sent from my iPhone using Tapatalk Quote
