Testing the waters
I'm thinking about selling my banshees. The fist 1 is a 1989 jarm that I build from the ground up about 2 years ago. It has a 7 mill cub that makes 102hp on pump gas. The second is a 4 mill cub that is brand new I have only been able to run it through a couple heat cycles. Below are the specs
1989 7mill
Motor:
7mill cub cylinders ported by D&M racing
7mm crankwor billet crank
Hinson clutch basket.
Mattoon lockup
Chariot billet 1 piece intakes
Vforce 4 reeds
Keihen 39mm carve with chariot billet bowls
Shearer bigbore inframes
Converted to dc power for hid
Chassis:
Lightened 1989 frame with chromoly subframe
+2 -1 metal tech j-arms
13.5 Marvin Shaw hill shooter from shocks
+10 metal tech swingarm
Works ultra cross rear shock
Jj&a hillshooter axle
Drag cut Douglas wheels front and back
22x11x8 10 paddle extremes
Lone star antivibe steering stem
Painted full of plastics
The second bike is a 1993 4 mill cub
Motor:
4mill cub cylinder
4mill hotrod crank
Chariot clutch basket
Direct drive lockup
35mm keihin pwk
Chariot 1 piece intakes
Vforce 4 reeds
Sheare inframe small bores
Converted to dc power for hids
Chassis:
1993 chassis lightened with chromoly subframe
Lone star +2 +1 a-arms
Works double rates in front
+8 metal tech swingarm
Works black widow rear shock
I'm asking 7500 for the 7mill and 5500 for the 4mill. Pm me with any questions.
7a0148a0ace7f7013de74b81bdb766dd.jpge48019eb278e7d50a95734a32710ab8e.jpgb2c57b4f0ba4a27624086fb5d0c055f5.jpg6ab20032e9a70a46ce4641c2ccc2bdc8.jpg201f60b86e2ba43cf146316cf15f6b6a.jpge8e2bff796207d5d0c7568999f6385fb.jpg
  • 2 weeks later...
