You should be able to turn the pressure plate by hand with the clutch lever pulled. With the lever out you should still be able to easily turn the adjuster, or ideally be able to move it in and out a tad. In this case, mine had no movement in, but would still move enough that it is acceptable.
https://m.youtube.com/watch?v=7g41kPgZIXs
Sent from my STV100-1 using Tapatalk
