I had another thread with my issue, but its no longer letting me reply to post.  what could my problem be?   I have a banshee of course, that has raw fuel in the exhaust pipe.  I know this because I went to run my leak down tester, which didn't go well at all. I poured raw fuel out of the first pipe to the cylinder.  What can cause this?  Also it smokes white when its running.
White smoke is going to come from coolant. If you have raw fuel in your pipes your bottom end is most likely going to be full too (do not try and kick it, it will "hydrolock" and bend a rod). If it is fuel it's cause the needle and seat is not fuctioning properly. If it's coolant is going to be most likely a head gasket.. (Orings if you have a billet head)
Edited by JUSTWANNARACE
Bad reeds can cause raw fuel blow by, stuck float, someone tapped an extra fuel line through the boost bottle holes for powa. Are the overflow circuits in your carbs functioning. What kind of bowls
