Bansheeman3466 Posted April 11, 2017 Report Posted April 11, 2017 My 2001 Yamaha banshee will move a little bit when I have the clutch pulled in and I rev it. Even when it's not on a hill I will rev it when it's in first gear and the quad will move a little bit. I have a Hinson clutch basket. I just want to know if this is normal or if there's something wrong with my clutch. Quote
Ayesully810 Posted April 11, 2017 Report Posted April 11, 2017 Try adjusting your clutch and making sure that is right. Also you can drain your fluids, remove clutch cover and inspect your pressure plate, hub, and basket. A worn hub and basket will cause some clutch creep. Quote
