Anybody have any luck with a lubricant that lasts on cables. Seems like mine are always dry. I just got new ones and want to try to make them last as long as possible. Someone said CRC power lube. I've used cable lube but it seems to just gunk up. Thanks
Does it ooz(spelling?) lube out at the perch side where you put it in? I have an older different model. It makes a mess. But works.
And the we've folks, don't use wd40 for something like that.
