Hello all,
I have a stock 97 banshee. It ran ok before I did the tors elimination. Now once the engine is warm , it idles high and it's starts vibrating and there in a tapping sound a few times. What should I check and do first to find out what it could be? I am a total noob at quads. Thank you.
Check for air leaks to start.   If that checks out synchronize the carbs, make sure you check synch both on the idle stops and off to make sure the cables are adjusted properly as well.
Do you have a manual? If u dont buy one if ur new to this stuff.
How do the plugs look? That can yell u if it lean,
And go back over all the simple stuff to like if u have the hose clamps tight on carb boots, no rips, sync carbs.
