sheerider11 Posted November 15, 2016 Report Posted November 15, 2016 So this is a lever i bought to see if i wanted to buy more and use this as my main lever. Not crazy about it so i wont be making more of this specific lever. -shorty lever -Ez pull mod that i do by hand in my garage. -Swaped the phillips screws for allen head. Theres a few things that I want. I want a buyer that will put this on there bike within a few days. Give me honest feed back on what you liked /didn't like. Looks fit finish. Did it change the pull. Was the install easy. Do you want instruction. Get a ride in and see how you/it feels. Swap between the 2 holes and note the difference. The lever is free to anyone that can pull that off for me in a timely fashion. Also, I have the right to tell you no. I want a long time active member here. We will also swap numbers and discuss the lever back and forth. Either through text or a phone call. Quote
hercalmighty Posted November 15, 2016 Report Posted November 15, 2016 Hey Sheerider11. Do you happen to have a pic of this installed with the lever pulled in? Sent from my VS990 using Tapatalk Quote
sheerider11 Posted November 15, 2016 Author Report Posted November 15, 2016 Hey Sheerider11. Do you happen to have a pic of this installed with the lever pulled in? Sent from my VS990 using Tapatalk Nope. Do you need that?Do you need to see it with the cable installed? Quote
hercalmighty Posted November 15, 2016 Report Posted November 15, 2016 Just curious. I know the ez pull clutch I had the adjuster pivoted for the different holes. I wanted to see what the angle was in the cable Sent from my VS990 using Tapatalk Quote
sheerider11 Posted November 15, 2016 Author Report Posted November 15, 2016 Just curious. I know the ez pull clutch I had the adjuster pivoted for the different holes. I wanted to see what the angle was in the cable Sent from my VS990 using Tapatalk Yup I got that covered on the first one I did. Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
sheerider11 Posted November 15, 2016 Author Report Posted November 15, 2016 Just curious. I know the ez pull clutch I had the adjuster pivoted for the different holes. I wanted to see what the angle was in the cable Sent from my VS990 using Tapatalk Like you said, it took a few times on and off to get the cut right. The cable was to wrapped around the corner so I had to cut the channel deeper. You do need to run the adjuster out a bit more from the original spot. But not much Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
