PARTS LIST UPDATED AND PRICES REDUCED
*******PRICES ARE IN CANADIAN DOLLARS*******
Front end hydro dynamics +2"(shocks,a-arms,tie rods,brake line)-SOLD
1 spindle-$20
Front callipers and rotors-$100
Front brake master cylinder-$20
Frame(right side broken grab bar mount)-$100
Radiator-SOLD
Bumper-$24
Rear end (wheel hubs,axle,sprocket hub,rotor hub,sprocket,rotor,lock nut,bearing carrier)-SOLD
Front wheels-$200
Rear wheels-$150
Swingarm-$100
Rear shock-SOLD
Rear brake setup-SOLD
Swingarm skidplate-SOLD
Frame skidplate-SOLD
Plastics-$100
Seat-$25
Steering stem-$40
Clutch cable/lever-$30
Throttle-SOLD
Throttle cable stainless-SOLD
Dynatek coil-SOLD
Stock cdi (95-96 plug-$150
Kompulsive Concepts custom cdi mount behind gas tank wiring harness-$80
Gas tank-$60
CPI big bore inframe exhaust with seals/clamps,springs,hangers-SOLD
38mm a/s pwk carbs-$300
CPI 521 super cub cylinder, 1 new piston kit,head,domes(one needs to be polished),new base gasket-SOLD
Billet intakes 38-41mm-$60
Upp intakes-SOLD
V-force4 reeds-SOLD
10mm wfm crank (needs new thrust washer installed)-$150
Transmission-$150
Gear shifter-$25
Engine front mounts-$20
Kick starter-$80
Clutch basket,hub,pressure plate,springs-$150
Clutch cover-$40
Ignition cover-$25
Stator with adjustable timing plate $60
Flywheel-$40
Front hubs-$80
Case saver-SOLD
Cdi pro rev box(95-96 plug)-SOLD
Steering stabilizer-SOLD
Foot pegs-$20
Chain-$30
Chain rollers-$20
Handle bars-$10
K&n pod air filters-SOLD
Located in Airdrie,Alberta
Txt 780-518-9492
