Ktm250r
Everything posted by Ktm250r
KTM chassis/banshee engine hybrid
Ktm250r replied to Ktm250r's topic in YFZ - Banshee Conversion Forum
Good chance I might get LED to do the pipes, they built me a KTM with trx250r and puma 431 big bore already but cost me a lot of cash and I'm in Canada and the exchange rate isn't what it used to be lol plus I had to go pick it up and bring it back when it was done and didn't have good luck at the border crossing lol I'm gonna have this one built locally besides the pipes, also wanna run smartcarbs, not sure what engine setup to use yet :s Sent from my iPhone using Tapatalk -
That's what I'm wondering about (side to side) which way it would be better balanced, I'm not sure how the engine sits in a banshee frame and it seems the clutch side of this engine sticks out quite a bit, I know I will need to cut out the 2 diagonal pieces of the frame to make room for the exhaust. Sent from my iPhone using Tapatalk -
I'm in the early stages of this build and looking for some input, with the sprockets lined up together it makes the cylinders and carbs off centre with the frame but the kick start and gear shifter shafts seem to have good placement as well in this position, would it be more important to have the cylinders centred and use an offset sprocket? Pics show how the engine sits with sprockets lined up. Sent from my iPhone using Tapatalk
*****521 SUPER CUB PART OUT*****
Ktm250r replied to Ktm250r's topic in For Sale - Parts & Accessories
Crank-SOLD Sent from my iPhone using Tapatalk -
Crank is still available Sent from my iPhone using Tapatalk -
PARTS LIST UPDATED AND PRICES REDUCED *******PRICES ARE IN CANADIAN DOLLARS******* Front end hydro dynamics +2"(shocks,a-arms,tie rods,brake line)-SOLD 1 spindle-$20 Front callipers and rotors-$100 Front brake master cylinder-$20 Frame(right side broken grab bar mount)-$100 Radiator-SOLD Bumper-$24 Rear end (wheel hubs,axle,sprocket hub,rotor hub,sprocket,rotor,lock nut,bearing carrier)-SOLD Front wheels-$200 Rear wheels-$150 Swingarm-$100 Rear shock-SOLD Rear brake setup-SOLD Swingarm skidplate-SOLD Frame skidplate-SOLD Plastics-$100 Seat-$25 Steering stem-$40 Clutch cable/lever-$30 Throttle-SOLD Throttle cable stainless-SOLD Dynatek coil-SOLD Stock cdi (95-96 plug-$150 Kompulsive Concepts custom cdi mount behind gas tank wiring harness-$80 Gas tank-$60 CPI big bore inframe exhaust with seals/clamps,springs,hangers-SOLD 38mm a/s pwk carbs-$300 CPI 521 super cub cylinder, 1 new piston kit,head,domes(one needs to be polished),new base gasket-SOLD Billet intakes 38-41mm-$60 Upp intakes-SOLD V-force4 reeds-SOLD 10mm wfm crank (needs new thrust washer installed)-$150 Transmission-$150 Gear shifter-$25 Engine front mounts-$20 Kick starter-$80 Clutch basket,hub,pressure plate,springs-$150 Clutch cover-$40 Ignition cover-$25 Stator with adjustable timing plate $60 Flywheel-$40 Front hubs-$80 Case saver-SOLD Cdi pro rev box(95-96 plug)-SOLD Steering stabilizer-SOLD Foot pegs-$20 Chain-$30 Chain rollers-$20 Handle bars-$10 K&n pod air filters-SOLD Located in Airdrie,Alberta Txt 780-518-9492 -
Reeds are SOLD Sent from my iPhone using Tapatalk -
Pm'd you Sent from my iPhone using Tapatalk -
No, but they are Canadian dollar Sent from my iPhone using Tapatalk -
Front end hydro dynamics +2"(shocks,a-arms,tie rods,brake line)-$700 Radiator Rear end (wheel hubs,sprocket hub,rotor hub,sprocket,rotor,lock nut,bearing carrier Front wheels Rear wheels Swingarm skidplate Frame skidplate Throttle cable stainless Dynatek coil Kompulsive Concepts custom cdi mount behind gas tank wiring harness CPI big bore inframe exhaust with seals/clamps,springs,hangers 38mm a/s pwk carbs CPI 521 super cub kit(damaged dome and piston,comes with new piston and base gasket) Billet intakes 38-41mm Upp intakes V-force4 reeds 10mm wfm crank (needs new thrust washer installed) Gear shifter Engine front mounts Case saver Steering stabilizer Chain Chain rollers Sent from my iPhone using Tapatalk -
Ok thanks -
Still trying to figure that out, says my files are too big to post, feel free to email me or txt until I figure it outEmail [email protected] Txt (780)518-9492 -
Also forgot to mention the rear end has billet lock nut,sprocket/rotor hubs, new oem axle and wheel hubs, new renthal sprocket, new rotor, new rad bearing carrier -
38-39mm no cross over tube holes -
***ALL PRICES ARE CANADIAN CURRENCY*** One dome and piston are damaged but cylinder is still good, thrust washer hit side of case trenching and broke, 90% of these parts are new with 1-2 hours, msg me for details Front end hydro dynamics +2"(shocks,a-arms,tie rods,brake line)-$700 Spindles-$100 Front callipers and rotors4-$150 Front brake master cylinder-$30 Frame(right side broken grab bar mount)-$200 Radiator-$100 Bumper-$50 Rear end (wheel hubs,sprocket hub,rotor hub,sprocket,rotor,lock nut,bearing carrier)-$1,000 Front wheels-$250 Rear wheels-$200 Swingarm-$150 Rear shock-$80 Rear brake setup-$80 Swingarm skidplate-$75 Frame skidplate-$75 Plastics-$150 Seat-$50 Steering stem-$80 Clutch cable/lever-$30 Throttle-$30 Throttle cable stainless-$50 Dynatek coil-$100 Stock cdi (95-96 plug-$200 Kompulsive Concepts custom cdi mount behind gas tank wiring harness-$80 Gas tank-$80 CPI big bore inframe exhaust with seals/clamps,springs,hangers-$500 38mm a/s pwk carbs-$400 CPI 521 super cub cylinder,Pistons,head,(includes 1 new piston kit and base gasket) $1,200 Billet intakes 38-41mm-$80 Upp intakes-$100 V-force4 reeds-$200 10mm wfm crank (needs new thrust washer installed)-$200 Transmission-$200 Gear shifter-$25 Engine front mounts-$25 Kick starter-$80 Clutch basket,hub,pressure plate,springs-$200 Clutch cover-$50 Ignition cover-$25 Stator with adjustable timing plate $75 Flywheel-$60 Front hubs-$100 Case saver-$30 Cdi pro rev box(95-96 plug)-$80 Steering stabilizer-$120 Foot pegs-$25 Chain-$30 Chain rollers-$20 Handle bars-$10 Located in Airdrie, Alberta Txt 780-518-9492
Thank guys
Super cub? It's the $2,999 kit from bp racing, they list it as super cub, I have no idea what the dome size is or what porting it has :s what pipe should I run on it? I have a new set of cpi raw big bores but not to happy with the fitment, left side hits the head and pod filter on the stator side no matter how I shim them :s I've read that shearer small bore fit good? But can they be run on this size engine?
Thanks for the reply, Just checked it and has 170, 55, ddj 3rd clip, #7 slide
Just bought this banshee with a new 521 kit installed, was told it only has about 30 min run time on it, he had fmf pipes on it for the break in, I took off the pipes to mount cpi big bore in frame but noticed lots of oil residue in the fmf, I'm guessing he had pretty rich for break in, mods are 521 cheetah kit, v force 4 reeds, 38 or 39 pwk carbs with k&n pod filters, cpi in frame big bore exhaust, dynatek coil, c12 @ 40:1 castor 927, I'm at 3575 feet, haven't checked the jetting yet, just wondering if anyone with the same setup could help me with a starting point for jetting? Thanks in adavance
