Guest bansheeman654321 Posted December 5, 2003 Report Posted December 5, 2003 theres alot of blue whiteish puffy smoke coming out of ma shee when its cole when i start it, and after that it goes down, but it still smokeds is this ok, iknwots a lil l ean and im mixing the mixing the gads richers than normal, Quote
txblueshee Posted December 5, 2003 Report Posted December 5, 2003 Mine smokes a bit when cold (not like squito fogger) then it clears up all the way when I'm wide open and the engine is warmed up. Putting around in the woods it smokes a little also. Been running strong for almost a year now. Mike Quote
fixitrod Posted December 5, 2003 Report Posted December 5, 2003 It's just the oil residue. When the motor is cold, it doesn't burn the oil as clean as when warmed up. All 2 strokes smoke more when first started. Since it's blue... it's oil. No worries. Are you mixing more gas or more oil. If you add oil your making the fuel mix leaner. Quote
Demon350 Posted December 6, 2003 Report Posted December 6, 2003 yea every 2stroke smokes i think... mines used to smoke like hell untill i started using fully synthetic oil, now its not so bad, but when i had my stock pipes and some cheap oil, my smoke was blue.. realy blue like cudnt see nothing behind me bad for a few miles, ttyl peace Quote
