NJ Engine Building
njdread77
I'm in Passaic Nj, about 15 mins from the GW bridge. I just added VForce 4 reeds, cool head with 21cc domes, new stator and adjustable timing plate, radiator, and I removed the TORS and added the idle screws. I'd just like to get everything dialed in and running right. Now that I removed the TORS I can't get the bike started anymore. Think I may have messed up the right side carb
If you happened to take the carbs apart make sure float bowls are on the right carbs, I had them switched up and it didn't start for shit. As already stated make sure choke tube is there, and make sure the slides are in with the half moon cut out facing towards the air box... I'm pretty sure  at one time or another I over-looked all of these...
  • 3 weeks later...
