I'm in Passaic Nj, about 15 mins from the GW bridge. I just added VForce 4 reeds, cool head with 21cc domes, new stator and adjustable timing plate, radiator, and I removed the TORS and added the idle screws. I'd just like to get everything dialed in and running right. Now that I removed the TORS I can't get the bike started anymore. Think I may have messed up the right side carb
also did you unwire the brains of the tors?  if it still thinks you have them, it wont let the bike run for shit.
Okay, you did a few things.
The tors and the stator.
Make sure you have spark. Make sure the choke tube is back like ZillaFreak said.
Did the idle screws move the slides?
What kind of stator?
If you happened to take the carbs apart make sure float bowls are on the right carbs, I had them switched up and it didn't start for shit. As already stated make sure choke tube is there, and make sure the slides are in with the half moon cut out facing towards the air box... I'm pretty sure  at one time or another I over-looked all of these...
  • 3 weeks later...
Where do you guys tune these things in at? John (nyuk) said Jersey frowns upon quad riding so I'd think NY would be worse.
I have a decent street in front of my house. But it doesn't take long to tune them in.
