maggdog Posted July 14, 2016 Report Posted July 14, 2016 Hi guys Sometimes after warmmed up when i apply a WOT. Not response correctly. It give a kind of jostle (or sound choky) and after I keep WOT a few seconds starts to respose slowly and i can run full throttle. What the problem? Stock carbs with 300 mains 27.5 pilots (tors on it but disconnected) V force 4 Shaved head Stock cdi coil and stator Plugs looks brown color, not rich, not lean No hard start Before put the v force and shave the head also made all that Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 Fmf pipes and silencers Intakes? So i suppose is stock boots with crossover tube. not cyl port Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 Stock airbox with lid Sent from my SM-A500Y using Tapatalk Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 300 is a lot. Where is your air screw? 1 Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 1.5 turns out is the airscrew Sent from my SM-A500Y using Tapatalk Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 Which needle and position? Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 4th clip from flat end Sent from my SM-A500Y using Tapatalk Quote
Power_Man Posted July 14, 2016 Report Posted July 14, 2016 did you do have the cards off right before this happened? Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 4th clip from flat end Sent from my SM-A500Y using Tapatalk Okay. First thing to do is make sure the slides are in the correct carbs. Is it good gas? Clean correct plugs? Ratio correct? Have you done anything to see if you can fix it Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 Okay. First thing to do is make sure the slides are in the correct carbs. Is it good gas? Clean correct plugs? Ratio correct? Have you done anything to see if you can fix it Yes the slides are in correct position, half moon in the airbox direction Yes is a good gas because other buddies don't have trouble with the same gas I have not cleane the plugs, ¿how to do? And what plugs? Spark plugs? Harness plugs? Mix ratio? I use 32:1 ratio Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 did you do have the cards off right before this happened?I ever had this problem with this quad With all number of jets, 200, 245, 280, 300 and the same mods that i've post before Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 Okay. First thing to do is make sure the slides are in the correct carbs. Is it good gas? Clean correct plugs? Ratio correct? Have you done anything to see if you can fix it My banshee do similar like this but in high revs and the tors and parking brake and is disconnected https://youtu.be/INQF4uY-Q2w Sent from my SM-A500Y using Tapatalk Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 Did you ohm the coil? Pick up gap okay? 300 and 4th notch is fairly rich for you too Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 Did you ohm the coil? Pick up gap okay? 300 and 4th notch is fairly rich for you too Sent from my SAMSUNG-SM-G890A using Tapatalk Not. but i'll do Yes pick up gap is okay What jetting and notch do you recommend? Sent from my SM-A500Y using Tapatalk Quote
