sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 Not. but i'll do Yes pick up gap is okay What jetting and notch do you recommend? Sent from my SM-A500Y using Tapatalk 270 and middle clip with 1.5 out I had a ported bike with a 300. With your lid still on your way rich. But I can't be 100% because for all I know the electrical isn't up to par Sent from my SAMSUNG-SM-G890A using Tapatalk 1 Quote
maggdog Posted July 14, 2016 Author Report Posted July 14, 2016 270 and middle clip with 1.5 out I had a ported bike with a 300. With your lid still on your way rich. But I can't be 100% because for all I know the electrical isn't up to par Sent from my SAMSUNG-SM-G890A using Tapatalk I'll try to change this jetting and check the electrical system Thanks alot Sent from my SM-A500Y using Tapatalk Quote
Larry's Shee Posted July 15, 2016 Report Posted July 15, 2016 Seems to be a translation issue. Did this start suddenly? Was it after doing some work on it? Have you tried NEW plugs? Are the carbs pussy clean and float level set? Choke crossover tube on ? If yes to all those questions, go down one jet size at a time. NOBODY can tell you what size you need exactly, every engine is different as are set ups and conditions. 1 Quote
maggdog Posted July 15, 2016 Author Report Posted July 15, 2016 Seems to be a translation issue. Did this start suddenly? Was it after doing some work on it? Have you tried NEW plugs? Are the carbs pussy clean and float level set? Choke crossover tube on ? If yes to all those questions, go down one jet size at a time. NOBODY can tell you what size you need exactly, every engine is different as are set ups and conditions. Well, since i bought the banshee comes with this issue First was that i try to run WOT and the banshee turn off. and now this problem Carbs cleaned and a lot new plugs and still with the problem I'll try to change the jet size Sent from my SM-A500Y using Tapatalk Quote
Larry's Shee Posted July 15, 2016 Report Posted July 15, 2016 Are you familiar with how to do a plug chop/ plug read? Presume air filter is clean and no major dents in pipes or plugged silencers ?? Quote
maggdog Posted July 15, 2016 Author Report Posted July 15, 2016 Are you familiar with how to do a plug chop/ plug read? Presume air filter is clean and no major dents in pipes or plugged silencers ?? Sure I know how do Yes not dents on pipes filter clear Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 15, 2016 Author Report Posted July 15, 2016 Thus looks like old plugs Sent from my SM-A500Y using Tapatalk Quote
maggdog Posted July 18, 2016 Author Report Posted July 18, 2016 Ok, i think I figure out the problem keep the main and all that but only change needle position the 4th to middle pos and run great now, thanks for ideas guys Sent from my SM-A500Y using Tapatalk Quote
