freshsbanshee Posted July 13, 2016 Report Posted July 13, 2016 I switched from stock carbs to 35mm carbs with shearers exhaust @sea level with k&n pods trying to get the most out my bike what jets ppl are running with 35mm carbs and close or same set up Ps this is a 4mil serval motor Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 13, 2016 Report Posted July 13, 2016 (edited) I switched from stock carbs to 35mm carbs with shearers exhaust @sea level with k&n pods trying to get the most out my bike what jets ppl are running with 35mm carbs and close or same set up Ps this is a 4mil serval motor Sent from my SAMSUNG-SM-G930A using Tapatalk Im at 600-700 above sea level and I have a 397 4 Mil stock cylinder with Sb shearers 35 pwks, vf3, redline porting, pump gas and my Jetting is at 145 main, 48 pilots, CELs on the 5th groove with air screws 2 turns out and my jetting is about perfect on days that its not over 80 degrees. Edited July 13, 2016 by Ayesully810 Quote
sheerider11 Posted July 13, 2016 Report Posted July 13, 2016 I'm at 160 58. But I'm super conservative right now as I just had the engine rebuilt. On the dyno I was down to like a 150 50 Maybe less I'm not sure that was a while ago. 4 mil stock cylinder. But I've seenever people be bigger and lower then my jets Quote
freshsbanshee Posted July 13, 2016 Author Report Posted July 13, 2016 Im at 600-700 above sea level and I have a 397 4 Mil stock cylinder with Sb shearers 35 pwks, vf3, redline porting, pump gas and my Jetting is at 145 main, 48 pilots, CELs on the 5th groove with air screws 2 turns out and my jetting is about perfect on days that its not over 80 degrees.Thanks I forgot 2 say I have v4 reeds and fast Racing clean up port I have 160 main jets and 48 pilot middle clip on needle but it was hotter then it has bin butt all help is good help Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 13, 2016 Report Posted July 13, 2016 Thanks I forgot 2 say I have v4 reeds and fast Racing clean up port I have 160 main jets and 48 pilot middle clip on needle but it was hotter then it has bin butt all help is good help Sent from my SAMSUNG-SM-G930A using Tapatalk Is it not running right? Quote
freshsbanshee Posted July 14, 2016 Author Report Posted July 14, 2016 Is it not running right?I feel like it's not running right felt more power with the stock carbs b4 I do a leak test and plug chop I wanted 2 see what other ppl are running so I could try a few different jets and see how it feels but I never ran 35 b4 fast Racing recommend it told me it would help my all around performance and more top end Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 14, 2016 Report Posted July 14, 2016 I was taught that its better when you tune, begin tuning with being on the rich side and lean down from there until you find what works with being a little more on the rich side to be safe. So if your running really rich right now it prolly wont take much to find what works. Search the forums for other posts and see if you can find another bike that is close to your mods and sea level, you might find some good info there as well. I'm sure some other people will chime in with good advice and direction as well. 1 Quote
freshsbanshee Posted July 14, 2016 Author Report Posted July 14, 2016 I was taught that its better when you tune, begin tuning with being on the rich side and lean down from there until you find what works with being a little more on the rich side to be safe. So if your running really rich right now it prolly wont take much to find what works. Search the forums for other posts and see if you can find another bike that is close to your mods and sea level, you might find some good info there as well. I'm sure some other people will chime in with good advice and direction as well.Thanks I'm going 2 order a few jets 145-158 and a few pilots I got my carbs with jets 160-170 I'll just play trial and error til I get in contact with sleeper06 to do a leak test and plug chop I feel I'm not 2 far off also how do u know when 2 go up and down on the jets for what temp outside like dude said he has his jetted for 80° weather so if it's hotter/colder do u go one size up or down ? I always went one or two sizes up in the winter was I doing this right Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 14, 2016 Report Posted July 14, 2016 (edited) Thanks I'm going 2 order a few jets 145-158 and a few pilots I got my carbs with jets 160-170 I'll just play trial and error til I get in contact with sleeper06 to do a leak test and plug chop I feel I'm not 2 far off also how do u know when 2 go up and down on the jets for what temp outside like dude said he has his jetted for 80° weather so if it's hotter/colder do u go one size up or down ? I always went one or two sizes up in the winter was I doing this right Sent from my SAMSUNG-SM-G930A using Tapatalk Driveline in Ortonville Michigan hooked me up on the dyno and got me all dialed in.. We did it on a almost 90 degree day and it was setup to run safely on the rich side. From what Ive read on the forums if you are jetted that way, you dont have to mess with jetting between mild weather changes. On days its 85-90 it runs more rich but if I go to ride on a 65-70 degree day, no worries, it will run great. As far as jet changes between more extreme weather swings Idk I wanna say I read somewhere on here a guy goes up a main jet size for every 30 degrees it drops but that probably isnt right.. Im still learning myself, more experienced tuners will correct me if im wrong or chime in with what you ought to do. Edited July 14, 2016 by Ayesully810 Quote
freshsbanshee Posted July 14, 2016 Author Report Posted July 14, 2016 I'm at 160 58. But I'm super conservative right now as I just had the engine rebuilt. On the dyno I was down to like a 150 50 Maybe less I'm not sure that was a while ago. 4 mil stock cylinder. But I've seenever people be bigger and lower then my jets What exhaust are u running and elevation for set up Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
freshsbanshee Posted July 14, 2016 Author Report Posted July 14, 2016 Driveline in Ortonville Michigan hooked me up on the dyno and got me all dialed in.. We did it on a almost 90 degree day and it was setup to run safely on the rich side. From what Ive read on the forums if you are jetted that way, you dont have to mess with jetting between mild weather changes. On days its 85-90 it runs more rich but if I go to ride on a 65-70 degree day, no worries, it will run great. As far as jet changes between more extreme weather swings Idk I wanna say I read somewhere on here a guy goes up a main jet size for every 30 degrees it drops but that probably isnt right.. Im still learning myself, more experienced tuners will correct me if im wrong or chime in with what you ought to do.Thanks bro I wish they had dyna in ny but you definitely a big help I'll try n stay a Lil rich like u said hopefully a few more pros chime Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 14, 2016 Report Posted July 14, 2016 Thanks bro I wish they had dyna in ny but you definitely a big help I'll try n stay a Lil rich like u said hopefully a few more pros chime Sent from my SAMSUNG-SM-G930A using Tapatalk People are probably going to ask the symptoms of what your bike is doing to not make power btw and will ask what your plugs look like. Quote
sheerider11 Posted July 14, 2016 Report Posted July 14, 2016 What exhaust are u running and elevation for set up Sent from my SAMSUNG-SM-G930A using Tapatalk Cpi Sea level Sent from my SAMSUNG-SM-G890A using Tapatalk Quote
freshsbanshee Posted July 14, 2016 Author Report Posted July 14, 2016 Ima take a pic of the plugs and make a Lil video but the power band comes on later like it's a slight delay or bog 1/2 - 3/4 throttle then pulls strong 3/4 to full throttle comes on strong Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Ayesully810 Posted July 14, 2016 Report Posted July 14, 2016 Did you just switch pipes too since your carb change? or did you run your shearers with your stock carbs as well? In your bio on your page it says you have T5's along with your old jetting specs on your stockers Quote
