nastyracing Posted May 20, 2016 Report Posted May 20, 2016 I'm looking for the gear that goes on crank after primary gear that drive water pump, 64.5 mm stock stroke Pistons , stock studs for cylinders, stock basket. Thin washer that lays ontop of seal where clutch actuator slides three top of cases. Quote
Shee_fast Posted May 20, 2016 Report Posted May 20, 2016 I'm looking for the gear that goes on crank after primary gear that drive water pump, 64.5 mm stock stroke Pistons , stock studs for cylinders, stock basket. Thin washer that lays ontop of seal where clutch actuator slides three top of cases.I have the gear and washer let know if interested Sent from my VS810PP using Tapatalk Quote
VegasJeff Posted May 20, 2016 Report Posted May 20, 2016 I'm looking for the gear that goes on crank after primary gear that drive water pump, 64.5 mm stock stroke Pistons , stock studs for cylinders, stock basket. Thin washer that lays ontop of seal where clutch actuator slides three top of cases.head studs? If so , I have a set and the washer. Text me 702-501-8770 Quote
