I was wondering if I could run yfz450r shocks on Alba Racing long travel a-arms. The yfz450r front Shock is 18 1/4". Alba says that the long travel shock length for the a-arms is 17 1/2". Can I use the yfz450r shocks or would they not work?
Don't do it don't do it. I contemplated this and when I read into it and asked around I was told, I might as ask use my money as kindling to start my barn fire! Save up get a nice set of entry level set of aftermarket shocks and be happy and worry free!
Yeah, it'll probably be soft, but the alba arms with the brackets are designed to be used with 17.5" shocks or 14.5" standard length.  YFZ are 15.5" iirc.  The leverage ratios are different and your ride quality will be piss poor.  It'll be wider and ride about like it does with the factory suspension.  Do it right or don't do it.
You'll think it's fine until you ride around people that are really fast and you get left behind because your suspension won't allow you to keep up.
