Hi guys, first time I've taken these carbs apart to thoroughly clean and inspect them and I'm a little confused. I believe there are supposed to be 2 floats, however I only have one inside one of the two. Is this normal or what?
Ignore the shit inside it, that's why it's apart. Lol
Ok I'll check the other one and see if they're both like that.
It caught me off guard, just wanted to ask you all.
So I'm not familiar but which side would it go on? It seems to be offset. It fits snug on one side and loosely on the other
When I say snug I mean in relation to the gold piece (not sure on the name)
It should be relatively loose against the float tang thing
Make sure they dont hang up on the bowls. Usually there are clearance issue with billet bowls. Also the float pin goes furthest away from needle valve when running a pump. Those look like alky needle and seat 3.3 is for a pump.
