I rode my banshee and the next day I go to ride the left cylinder is dead I know it's gettin fuel cause my headers fill up with gas that isn't burning and when I empty the header of the extra gas it fires case it's pushing the rest of the gas out but it's very weak. and it is getting fire so what y'all thinks the problem
check the float needle. compression is good because it's a new topend? you know how many 5 minute old topends i have seen with a broken ring because the ports were not chamfered?
It takes 2 minutes to do a comp test. Also rule out another possible issue.
Like stated, just because it's new that doesn't mean it's okay.
I'd do that before I start taking shit apart also. Do all the simple test.
Then you can visually check if you have spark too.
