464 t-rex
Selling a T-Rex dune motor, complete w/PVs, Mikuni carbs, DD lockup cover, billet stator cover ect. All polished, setup for gasoline, no override. Motor Ran excellent w/BB Shearer pipes when pulled from bike. Pulled the head and took some measurements. 464cc, 69mm bore, 62mm stroke(8mm stroker). Head is still removed.
The bad, found the left cyl has some damage/pitting on the quench pad/combustion chamber. Cyl still had good compression & bore looks ok. Suggest doing a topend but for the price you can't go wrong. $1700 no carbs or stator cover(will include DD clutch cover) or $2000 for everything plus fees.
D1328C0C-F973-439B-8487-50A3C6F15F22_zps
28803EFA-681F-43AB-9E77-1F7637FF5935_zps
19208359-D507-424C-BEE2-8153530DF359_zps
0E19261C-BE45-4389-A61E-4DF2C8A0E8C4_zps
00AAD120-7B79-4D75-9841-2A8C89BBD284_zps
9E6DCEBD-0728-4882-BD34-CA57AE6BCC23_zps
EF75BFF2-2D2A-4ACF-AF8B-93B805C50F12_zps
