Cylinders are off being re-plated.
Before i order new parts/gaskets i need to know how to attack this.
The previous work order states that it had a .012 cub gasket with a .047 squish.
Here are the details on it.
421 cub
24CC domes
wiesco 573M06800 pistons
39 PWK
shearer in-frames
i guess what i need to know is, is that squish good?
if i use a .012 gasket again will i get same squish.
i want to get most out of this engine on 94OCT Pump gas, while still being safe.
If your builder used .012 and it ran good and you were happy with it. Yea just get a .012 to put back in.
If it ran good, i probably would not be rebuilding it. lol
I think it had detonation. The reason i think it had that is because the motor vibrated at certain RPM/loads and it backed out on a WOT plug chop and started to seize the left cylinder.
The timing was at +4 and i was running 94 octane fuel.
Who built it? Why dont you ask him? I rebuild,and or inspect even when my bike runs great.
Could be lean for all we know causing the symptoms
Edited by possum
