1bad4millbanshee Posted October 19, 2015 Report Posted October 19, 2015 PARTS! Pictured: Cases no chain whack 150 shipped Chain whack repair 120 Headlights 65 Stock trans 125 Stock reed cages with new reeds 30 Billet inserts clutch 10 Throttle 40 Lightened flywheel 110 Stock flywheel 90 Stator 125 Cdi 60 Stock cyl w/ head 250 Stock stroke long Rod Drag ported cyl 68mm w/ Pistons 400 34 mm pj carbs w/ intakes and filters 240 38mm pj w/ intakes and filters 300 Not pictured: Coil Harness all stock stuff bumpers just ask if Ya need it I might have it thanx for looking all prices are shipped gift or Add PayPal fees thanx Quote
1bad4millbanshee Posted October 19, 2015 Author Report Posted October 19, 2015 Have a pro flow air box setup as well all electrical bolts frames stock a arms Lmk Quote
rad95banshee Posted October 26, 2015 Report Posted October 26, 2015 Do you have either set of carbs left? Sent from my VS985 4G using Tapatalk Quote
1bad4millbanshee Posted October 28, 2015 Author Report Posted October 28, 2015 I don't have a stator I still have the 34mm pjs and all worrys of other banshee parts still Quote
Shee_fast Posted October 28, 2015 Report Posted October 28, 2015 Idler gear? Push rod and ball Sent from my LGLS990 using Tapatalk Quote
mike0chek Posted October 29, 2015 Report Posted October 29, 2015 which set of cases are for sale? or both sets are? Quote
JMaN05 Posted October 30, 2015 Report Posted October 30, 2015 Are the stock cylinders and head in good shape? Useable? Bolt up and use? Quote
JMaN05 Posted October 30, 2015 Report Posted October 30, 2015 I need the boots that come off reed cage to carb. I developed a tear Quote
1bad4millbanshee Posted November 3, 2015 Author Report Posted November 3, 2015 Yes I have idler gear Both sets of cases are forsale Cylinders need bored and piston at 64mm I have the boots also sorry for late reply Quote
