banshee den Posted October 13, 2015 Report Posted October 13, 2015 Do you guys think I should do a bolt on sub frame? I ride Fast trails and screwing around. Quote
SandSlingerOR Posted October 14, 2015 Report Posted October 14, 2015 Hells yeah!!! But not needed, a weld on one works fine. Or the stock one is just as good Quote
banshee den Posted October 14, 2015 Author Report Posted October 14, 2015 do you run one? where did you get it are did you make one? Quote
bluebanshee98 Posted October 14, 2015 Report Posted October 14, 2015 The thing about a bolt on subframe is if you loop it, more then likely you will need for it to be replaced and buy another. With stock frame and grab bar usually just the bar will bend which would be a lot cheaper to replace Quote
banshee den Posted October 14, 2015 Author Report Posted October 14, 2015 yeah I know what you mean there. Quote
