slag_350300 Posted September 5, 2015 Report Posted September 5, 2015 (edited) I'm looking for a deal on top and bottom end parts. I am interested in some dune ported stock cylinders preferably no bigger than 66mm bore. Or a 421 serval top end with just a clean up port. Looking to build a trails bike so I'm steering away from drag porting and drag specific parts I need a 115 long rod 4 mil crank. Hotrods or RDZ Preferably low hours on the crank, and the cylinders I'm flexible if they need to be bored that's fine but they have to be somewhat good condition and like I said earlier id like to have some stock cylinders that are no greater than a 66mm bore. Also a few more parts I need are, billet intake manifold for 33mm carbs, modified shift star and the shift mod setup, and a lock up clutch assembly with case. Thanks in advance Edited September 5, 2015 by slag_350300 Quote
slag_350300 Posted September 6, 2015 Author Report Posted September 6, 2015 Update I just bought some 66mm dune ported cylinders so I am no longer looking for cylinders. I also would like to add to the wanted list is a billet head such as a fast, mod quad or noss in BLACK only. Domes I don't need. Thanks Quote
