Rebuilding from split cases up. Want to replace every seal, gasket, washer, part, etc.that is a good idea to do while torn apart as well as things like water impellar gear, etc..any recommendation on most complete gasket kits for quality and price from whomever and what things should be replaced for good measure. From reading see that certain c clips and things that may seem fine end up failing upon reuse.
Only buy OEM seals....I just ordered some off eBay thinking cheaper would save me money. But had to end up splitting cases again and changing them out but with OEM the second time. I got them from F.A.S.T racing. Sure they'll be able to help you out with everything else too I'd call and see!
Yeah looked at them and elsewhere. Only ? Is that i see complete engine kits with no listing of whats included. Is there one that has all top/botom end gaskets, crank/trans seals,etc. Of good quality/price. Guessing im buying top/bottom kits, separate seals, etc..
I'm not too sure on gasket kits. I just found one with the most stuff included and ordered it...can't say if there's a best kind or not for gaskets. I'd wait til business hours and give fast racing a call man. Sorry I couldn't help more
Thanks will look into it just want to order the most shit possible without ordering a list of shit. And meant to remention after my pos tablet didnt post my last post last time should i go ahead and do water pump impellar gear, c clips,etc.. while apart. Reading tells me some c clips anc shit that seem fine end up failing upon reuse.
