I have a stud that gets a pool of coolent around the nut on the outer left side of my head
i was thinking a new head gasket mite do the trick but it didnt
when i took the head off there was a good amount of corrosion around 4 of the studs and none of them were next to each other
Is this sht comon
i have never noticed a drop in coolent wich makes me think i am paraniod
but this quad cost more than most of the cars i have owned
Have it checked at a machine shop. I had a head that was .003 off and it dripped. If it's that slight, you can use a sealant on it. That high temp copper works. Another option is to have it milled. Might as well take a little off and add a little performance while your at it.
How did you notice the leak was happening. Was it after a rebuild or something.
I believe Boonman and ScottM here on the forum can hook you up.
i was cleanig my shee when i noticed a pool of coolent around one of the nuts on
the head stud, so i kept an eye on it and it seems to leak after i shut it down
i dont know of a good machine shop that works on shees so i am having my
brother check and see if the head is warped. my brother is a machinist.
i am thinking about letting him mill the head. does anyone know how much
i can take off with out making other changes
Thanx
