Bent Frame
Ronnie
Just fixed this issue on mine. Used a Bottle jack and a piece of wood.
Have to stand the bike upright or the bottle jack wont work. I wedged the block of wood in the seat cross member area for support for the base of the jack and the jack pad on the steering hoop. I initially didn't use a block of wood and just wedged the jack against the seat latch crossmember thing but it was starting to twist it. So I straightened it and then used the wood block to help.  Then took measurements from each side of the hoop to make sure it was even. It took more then one time bending cause I didn't want to over bend it.
  • Like 1
