Ronnie Posted June 26, 2015 Report Posted June 26, 2015 I flipped my bike over and it pushed the frame where the handle bars and radiator is about a half of inch. i cant get the plastics to line up right. How can i fix this? Its just bent a little. Any tricks? Would Yamaha fix it? Quote
sheerider11 Posted June 26, 2015 Report Posted June 26, 2015 Big pipe, hammer, come along, leave it. Quote
uman1030 Posted June 26, 2015 Report Posted June 26, 2015 Just fixed this issue on mine. Used a Bottle jack and a piece of wood. Have to stand the bike upright or the bottle jack wont work. I wedged the block of wood in the seat cross member area for support for the base of the jack and the jack pad on the steering hoop. I initially didn't use a block of wood and just wedged the jack against the seat latch crossmember thing but it was starting to twist it. So I straightened it and then used the wood block to help. Then took measurements from each side of the hoop to make sure it was even. It took more then one time bending cause I didn't want to over bend it. 1 Quote
