I want to convert over to DC, so far I've taken the lighting side ground off the stator plate and added wire. Now, I have a Regulator/Rectifier that came off a seadoo. It has 3 yellow wires and a red wire on it. Should I just hook the yellow wire off the stator and my floated ground to yellow wires, then the red would be my 12v+? I believe they ground off the case, so would i just run a ground from there and that be my 12v-?
http://www.regulatorrectifier.com/catalog/images/10-W005.jpg
Pic of the regicide I have
That looks like a single stage rectifier, but looks like the yellow wire by the red should be black.
A three phase would have have 3 yellow, black and a red.
^^^He's right. I just looked at the pic... pretty strange they'd do it like that! Looks like the same rectifier I'm using... aside from the yellow wire next to the red.
Kinda threw me off saying it grounded through the casing...
Well the rectifier I have at the house most definitely has 3 yellow wires and one red wire. I've also got another rectifier off a seadoo but it has two yellow, a black and a red. It would be the better one to use in this application?
Maybe my rectifier is bad, but my test light works when i touch the two leads off the stator (yellow/floated ground) but when i hook them to the rectifier i get nothing.
Trailtech regulator is the way to go here. i went through a few off random bikes with dismal results. Normally the stator gets hooked to 2 yellow wires on the regulator.
Damn, i guess i just wanted to see it work.
Two wires from the stator hooked to the two yellow on the reg
touch the black/red on the reg and i get nothing
hooked the black wire to the frame, also nothing
There's definitely AC output off the lighting coil, because it'll light up my headlights.
I guess i'll order a TT reg/rec and try that.
