badboy95 Posted June 11, 2015 Report Posted June 11, 2015 Took my top end apart to find Blaster pistons, they say 573m06700. Cylinders may need to be cleaned up....maybe a re-hone? What do you guys recommend? It still has the stock sleeve i am not sure what the maximum is on this. What can happen if it is run this way? Quote
badboy95 Posted June 11, 2015 Author Report Posted June 11, 2015 I am not sure if it is a stock sleeve or not i just assumed it was...but it is a blaster piston and is a 67 mm piston. It looks like the walls might be getting thin. So is it not possible to bore a stock cylinder that far? Quote
shanYE west Posted June 11, 2015 Report Posted June 11, 2015 I got a set of unported cylinders at 64.5 if you want to go back down to a stock piston. Quote
