TRYING TO DETERMINE WHAT THE INSIDE DIAMETER OF THE A/J ARM BUSHING IS OR THE METAL SLEEVE THAT SLIDES INSIDE THE BUSHING WHAT ITS OUTSIDE DIAMETER IS.
HOPEFULLY SOMEONE HAS ONE LAYING AROUND SOMEWHERE
THANKS
KEVIN
sorry for the confusion i need the inside diameter of the bushing and the outside diameter of the sleeve that slides through the center of the bushing
  ______1 1                 ________________________
1 _ _ _ _1 1   _ _ _ _  1 _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ 1 _ _ _ _ _
1______1 1                1_______________________1
              1 1
^BUSHING                      ^ SLEEVE THAT GOES INSIDE THE BUSHING
HOPE THIS HELPS
The inside of the bushing is aprox 10 mm.The only thing that goes through the bushing is the bolt that holds the a arms on.Are you talking about the end caps that sandwitch the arms inbetween the mounting points?
As seen in this link there are delrin bushings that press into the ends of all the arms.  then there are steel sleeves that slide through the middle of all the bushings.  theres short ones for the lower control arms and longer ones for the upper arms. after these are slid through the middle of the bushings then the end caps can go on.  heres a link...  http://www.amazon.com/American-Star-Banshee-YFZ450-Rebuild/dp/B0052UGBAQ
