badboy95 Posted June 9, 2015 Report Posted June 9, 2015 So I am new here and need some help! Just picked up a banshee that has a blown top end. I took the top end apart (has a cool head with 18 cc domes)and the cylinders had some porting done to them(they need re sleeving), the pistons turned out to be blaster piston. It has a hot rod crank and rod so I measured the rod and it is about 115 mm. What I would like to know is if I can use bone stock cylinders on this setup? Quote
badboy95 Posted June 9, 2015 Author Report Posted June 9, 2015 The old cylinders are too thin cant bore them anymore. OK so i need to have the new cylinders ported for a 4 mil long rod. Will I need special pistons to accommodate the long rod? Any idea what kind of numbers i can expect from this setup? It has 34 mm carbs, k&n clamp on filters no air box and cpi drag pipes. Quote
bigweav81 Posted June 9, 2015 Report Posted June 9, 2015 The old cylinders are too thin cant bore them anymore. OK so i need to have the new cylinders ported for a 4 mil long rod. Will I need special pistons to accommodate the long rod? Any idea what kind of numbers i can expect from this setup? It has 34 mm carbs, k&n clamp on filters no air box and cpi drag pipes.What numbers are on you're rods? sent from yo mammy house Quote
bigweav81 Posted June 9, 2015 Report Posted June 9, 2015 the rods say HR 158Was just curious. If your asking about the amount of power you can expect. Call a few site sponsors. sent from yo mammy house Quote
