ghost Posted November 27, 2003 Report Posted November 27, 2003 are the threads left handed or what? Is there a trick to geting the flywheel off without air tools. any help is appreciated. Quote
Holyman Posted November 27, 2003 Report Posted November 27, 2003 Yes they are left handed. Use a dental pick and make sure the threads in the flywheel are perfectly clean. Tighten the puller body into the flywheel and then install the center screw. Tighten it down with wrenches and then hit the center screw with a hammer. A couple solid hits should pop it right off. If not, get air tools. Quote
ghost Posted November 27, 2003 Author Report Posted November 27, 2003 thanks holyman, the hammer tricked worked great, it fell right off. anything speacial i should use to clean the stator with? Quote
