Yes they are left handed. Use a dental pick and make sure the threads in the flywheel are perfectly clean. Tighten the puller body into the flywheel and then install the center screw. Tighten it down with wrenches and then hit the center screw with a hammer. A couple solid hits should pop it right off.
If not, get air tools.
