b8es, b9es, b8eg b9eg if digital ignition, br series.
i personally like on stock or modded ignitions.  br8eix  gap at 18 tho for alky
The lower number plugs like br8es or b8es show heat easier than higher number b9 or b10 so I Tune it in on those and once it pulls clean I throw in br9eix at box gap. If you're combo is really high compression or making too much heat a 10 will work better.
Question on the plugs.... I heard that the bigger numbers are colder plugs is this correct....i went and got some news the other day, all they had was br9es and said they wouldnt recommend it since its a cooler plug? Just figured id ask
Yeah shees tuned in but i got some new plugs just to make sure im not super rich, sleeper06 thought i was really rich running 290 mains
Gotcha. If its completely pig fat and you run a cooler plug ,it's POSSIBLE to carbon one up. But if you're in the ball park,you'll be fine.
  • Like 1
