00BlueShee Posted November 27, 2003 Report Posted November 27, 2003 How much faster will a banshee with a +4mm stroker,vito's 8 hp pistons,Milled head,V-force reeds,and pro circuit pipes vs a banshee with P n P, Pro Circuit pipes, Shaved head .035" over, and Boyensen power reeds. What will I need to beat the Stroker banshee? thanks. Quote
boonman Posted November 27, 2003 Report Posted November 27, 2003 How much faster will a banshee with a +4mm stroker,vito's 8 hp pistons,Milled head,V-force reeds,and pro circuit pipes vs a banshee with P n P, Pro Circuit pipes, Shaved head .035" over, and Boyensen power reeds. What will I need to beat the Stroker banshee? thanks. Oh boy. First off, I notice that you list milled head with a stroker. You will either have to have custom domes cut to allow for the 2mm over on the up stroke, so milling it would be a given. In order to beat this banshee, you will need some serious business. Most likely a stroker yourself. Or alcohol..... Depending on if the stroker was properly built, it SHOULD have port work done to it to compensate. Are you ported? That banshee, properly set up, should be a ripper.... Quote
00BlueShee Posted November 29, 2003 Author Report Posted November 29, 2003 How much faster will a banshee with a +4mm stroker,vito's 8 hp pistons,Milled head,V-force reeds,and pro circuit pipes vs a banshee with P n P, Pro Circuit pipes, Shaved head .035" over, and Boyensen power reeds. What will I need to beat the Stroker banshee? thanks. Oh boy. First off, I notice that you list milled head with a stroker. You will either have to have custom domes cut to allow for the 2mm over on the up stroke, so milling it would be a given. In order to beat this banshee, you will need some serious business. Most likely a stroker yourself. Or alcohol..... Depending on if the stroker was properly built, it SHOULD have port work done to it to compensate. Are you ported? That banshee, properly set up, should be a ripper.... My banshee only has polished intake ports, My friends banshee with the stroker doesnt have any port and polish on the engine at all. If I was to get the Trinity 420 Long Rod Kit that should beat it right ? Quote
bignasty1 Posted November 29, 2003 Report Posted November 29, 2003 yeh it should if he doesnt have the port work and is just runnin a spacer plate. but you will need to get some porting, stroker, and a nice set of pipes and just have it set up correctly basicly to win. just my opinion but i could be wrong. Quote
