I have a crankshaft that the Web started to walk.. can I have it repressed and welded vs buying a new crank.. I also have another crank with a blown rod bearing that I got for 20 bucks off of someone.. just want to fix cheapest way out to have her running until I save coin to buy the new crank eventually and keep one of these others for a spare.. need a little help or advice I've never had any crank issues with other dirt bikes I had this would be my first messing with the bottom of a engine.. also my first time building a shee
Press is 10 bucks and weld around 60 I think trying to repair until I have the 400 450 for new crank is way cheaper.. and sleeper 06 how can I tell if it's will check out good.. all bearing seem fine spin good rod bearings as well.. just some rod side to side play from Web walking out and not very much.. I can tell cause one side pin is flush with outer edge of Web and other is in some from the edge
