thebloker Posted November 26, 2003 Report Posted November 26, 2003 I just finished putting my motor back together from Patriot Racing, and now it wont start. The bike is getting fuel, it has compression, it is getting a spark; it just won't start. I put new 28 pwk carbs on there, so I went with Dans reccomended ballpark jetting, but it is still a no go. I have a Vitos +4 timing advance, even if I put that key in backwards, it should still run shouldn't it? I am at 2200 ft, it is 66 degrees, Pro Circuit pipes, Duner Port Job, +4 timing and 28pwk carbs. Any help would be really apprecieated, seeing as I am supposed to be leaving for Glamis on Friday. If I can't get this bastard started, would there be any shops out in Glamis that would be open on Friday that could help me out. Thanks for all you help guys, thebloker Quote
thebloker Posted November 26, 2003 Author Report Posted November 26, 2003 Well disregard that last post, I got the damn thing running. All it took was me running up and down the street with it about 10 times before it sounded like it was in the process of being able to start. After kicking it over about 20 more times, it actually started. It starts every kick now; whats left is the actual jetting aspects of it to be fine tuned. At least I have something to look forward to on Thanksgiving. See you all in Glamis, Bloker Quote
