So i just recently did a top end rebuild and it started right up for me but as soon as it starts it just goes full throttle on me. Im gonna tear the carbs apart when i get home but i just wanted some other suggestions to look for as well. The throttle cable isnt bound. And yes i did a leak down test and it passed.
Cylinders bored to 66.25, full shearer exhaust, boyesen reed cage and reeds. i Run 32:1 and i have 320 main pilots and 30 pilots.
Thanks guys!
The carb slides are in backwards make sure the cutouts are toward the back
the slides only go in one way right?
I got the little notch that you can see through the peep holes on the sides of the carbs
Well i believe they can go in 180degrees larry ive done it forst hand since my cutout were in the fron and they need to be in the back so there for 180 degrees the wrong way...i know from first hand experience like a month ago
They can't go 180 out, but slides will fit in wrong carb backwards. Check that slides are bottoming out, gasket on top under cap, check again for leaks, especially carb boots.
my carb boots are lookin a little crappy
