Is there anyway that I can find out what cc my coolhead domes are? Just got this banshee and it was bored .030 but It needs a top end rebuild and I need to know if i will have to replace the coolhead domes and to what cc dome. don't want to use race gas. thanks for any help
I purchased the banshee with a blown top end.Im rebuilding top end. It will be stock bore. It was bored .030 over with coolheads with 17cc domes (just found the number stamp), vf3 reeds, fmf exhaust,no air box, 360 main jet ( I believe this is to rich just don't know where to start).
Do I need to change the coolhead domes? Im about 838 sea level also. Thanks for the help
Thanks 98_sheester would i be able to keep the 17cc domes with the stock jugs that i have? I would just have to buy race gas if I used the 17cc domes correct?
No throw those in the trash. You should run 22-23cc domes with a stick crank.
