Have my motor tore down an been reading about this shift drum mod. Anyone know number for the bearing for the non bearing aide after its been lathed down? Is it worth it having the mull star n detent arm and planning on sending my shift shaft to f.a.s.t.?
yes it is.
2 types of bearings  one after cutting or bushing the drum and stays on the drum.
other goes in the case and drum is cut down and preferable sleeve'd for bearing but not always.  most do the one that stays on the drum..   i had to find the bearing number out on my own.
