Power_Man Posted January 24, 2015 Report Posted January 24, 2015 put new brakes on this bike after picking it up few weeks ago. While I was at it, figured I'd do bearings too. After changing all part out, and snugging down caliper bolts, the outer pad is grabbing and binding on the rotor to the point you can't turn Hub. There is a washer that sits between the hub and spindle. If I remove that washer it just barley grabs it. Is that washer supposed to be there? If it is, what is my issue? Quote
Larry's Shee Posted January 26, 2015 Report Posted January 26, 2015 No idea about washer, look at a parts diagram. Did you use caliper grease on the pins? Are pins good? Not rusty/crusty or bent? Quote
Power_Man Posted January 27, 2015 Author Report Posted January 27, 2015 No idea about washer, look at a parts diagram. Did you use caliper grease on the pins? Are pins good? Not rusty/crusty or bent? didnt look bent or rusted, but i'll double check. There is no washer on the back side of the hub. http://www.bikebandit.com/oem-parts/2004-yamaha-banshee-350-yfz350s-front-wheel/o/m145575sch294347 Thanks for info. i checked out the diagram in the book, but i wanted to double check. Quote
