wizmopete Posted November 22, 2003 Report Posted November 22, 2003 my left cyl. wont idle w/out the choke pulled out. carbs are clean pilot& main,needle & seat are clean. I can get it to come on the main jet , but it falls off on the bottom wont even run with choke in. stator problem? I have no wiring diag. so i cant test stator output. Quote
SDD Posted November 22, 2003 Report Posted November 22, 2003 Did you make sure the tube between the carbs is there and isn't cracked? Quote
